주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 2DS는 3D 상단 화면 기능을 제외하고 Nintendo 3DS와 거의 동일한 하드웨어를 갖춘 보급형 휴대용 게임기입니다.
2DS Volume Slider Not Working
I have a 2DS that's stuck on max volume. The first time I took it apart to fix the issue, the problem was that the plastic volume slider was loose and physically detached from the actual component on the motherboard, just like in this tutorial. I fixed that issue and the volume slider is now aligned, but when I adjust the slider, the volume still doesn't change.
이미지
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi!
Can you put the volume slider to the lowest volume level and build it together?
If that isn't working as well (then you can say for sure it's there), you might want to replace it...
Soldering is required to get it replaced.
I think this one should fit: Amazon.com: Create idea 2pcs Game Consoles Volume Slider Switch Compatible with New 3DS 2DS XL LL Console : Video Games
Please let me know if you have any question!
Thanks!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Louisiana Hesitate 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 409
