주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년에 출시된 Acer Predator Helios 300은 여러 모델 번호로 식별할 수 있습니다. 대부분의 안내서는 모든 모델에 적용됩니다.
screw heads worn out
I normally clean my laptop frequently, but this time, when I tried to open it for a cleanup, the screw heads were worn. The screws used to hold the HDD drive had worn out. How do I remove it so that I can replace it with new ones? I did try using a bigger screwdriver and using a rubber band for grip. Even tried with a tape. Is there any way around?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
1. Double-check screwdriver fit
  • These screws are PH0 or PH00 (tiny Phillips).
  • Using anything bigger/smaller makes stripping worse. If you’ve been using a standard screwdriver, switching to a precision driver might still catch enough to back it out.
2. Press-down & twist (with grip help)
  • Place the laptop flat so the screw head faces straight up.
  • Push down hard with the correct precision bit, then twist very slowly.
  • You can add grip by putting a thin rubber band over the screw (fresh one, not too thick). You said you tried this, but it works best when paired with the exact-size driver.
3. Needle-nose pliers (best if screw is slightly raised)
  • On the Predator Helios HDD bracket, screws usually sit proud (not fully flush).
  • Try locking onto the screw’s rim with pliers and turning counter-clockwise.
4. Cut a slot (safe-ish here)
  • If it’s too stripped, you can carefully cut a new groove with a mini file or Dremel disk (tape around the area first).
  • Then use a small flathead screwdriver to remove it.
  • This is easier on the HDD bracket screws than on chassis screws since the drive bay is open.
  • A micro extractor kit (like iFixit’s) will bite into the stripped screw and pull it right out without damaging the bay.
  • Since Predator Helios screws are soft, this usually works very quickly.
6. Last resort: drill out
  • If completely flush and nothing else works, use a 1mm–1.5mm drill bit to carefully drill the screw head until it separates.
  • The bracket will lift off, leaving the shaft exposed, which can then be removed with pliers.
  • Risky — only do this if you’re confident.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I will try these and update on the same
댓글 달기
답변을 추가하세요
Abey Antony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 267
