주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2024년 4월에 출시된 Rakuten Kobo의 Clara BW(흑백) 전자책 리더기에 대한 수리 및 분해 정보입니다. 모델 번호 N365로 식별됩니다.
Screen replacement for P365
I have a Kobo Clara BW P365 but I only see an N365 screen available. The install instructions say to check which model you have as the images only apply to the N365 but it's not clear if the screen is compatible with the N365, N365B, and the P365.
Anyone know?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
The three Clara BW versions (N365, N365B, and P365) all require different replacement parts. We currently offer genuine replacement screens for the N365 and the P365 model. Unfortunately, the N365B screen is not available at this moment. You can always check the compatibility list on the product page for information on which devices the part fits or you can use our compatibility check tool by clicking "Compatible with your device?" on the product page.
Replace a cracked or malfunctioning display assembly for a Kobo Clara BW N365 E-reader. This assembly includes the display and the internal frame. 이미지
제품
Kobo Clara BW N365 Screen Assembly - Genuine
$94.99
Replace a cracked or malfunctioning display assembly for a Kobo Clara BW P365 E-reader. This assembly includes the display and the internal frame. 이미지
제품
Kobo Clara BW P365 Screen Assembly - Genuine
$94.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Any signs on motherboard, display, display connector? It's better to search with them than the device model. You can't know what display is used.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
I have not opened the damaged device up. I need to know if it's compatable before I order. Is there no way to contact ifixit? I can't seem to find anywhere to contact them on the website.
의 공유
@jon56733 No way to know your exact CHINA device part number before disassembling.
의 공유
I opened it up last night and visually, the screen and connectors from the screen look the same as what pictured in the instruction. The battery and MB are different, as that's the change from the N365 to the P365. I could not find any specific part number to compare to what is shown in the add so I'm at a loss. I found a link to email ifixit so I'll just have to wait and see if they respond.
Thanks,
의 공유
For anyone struggling with this in the future, I got an answer from Kobo... The N365 screen for sale on ifixit is compatable with the N365, N365B, and P365 version of the Clara BW.
의 공유
Good, you should try, sometimes it happens that fully compatible connector and display type works wrong on another revision of device.. but usually it will work.
의 공유
댓글 달기
답변을 추가하세요
Jon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 71
전체 시간: 864
