주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
10세대 Ford F-Series는 Ford Motor Company에서 생산한 픽업트럭 라인업으로, 1997년부터 2004년형 모델까지 판매되었습니다.
Why won't it move
My truck starts great sounds great but won't go forward or reverse
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Hi @barbiekeith
What year is the vehicle and what type of transmission does it have, automatic (AT) or manual (MT)?
의 공유
Maybe gearbox, transmisson or drive shaft is broken.
의 공유
Jayeff it is a 04 v6 heritage f-150. Automatic
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Hi @barbiekeith
Check if the shift linkage is OK and moving the lever on the transmission when moving the gear shift into gear.
Here's a video that may help.
It is better to have two people to do this. One to operate the gear shift in the cabin and the other to watch if the linkage is moving the lever on the transmission.
You could do it by yourself but it would mean having to get under the engine/transmission and look where the lever is positioned (or if the linkage is even still attached) and then get out from under and go and move the gear shift in the cabin and then get under the engine again to see if it has moved the lever.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Barbie keith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 195
