주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Golf Mk5는 2003년 가을 유럽에서 처음 출시되었으며, 2004년 초 영국 시장에 진출했습니다. 북미 시장에서는 폭스바겐(Volkswagen)이 2006년 해당 차량을 도입하면서 Rabbit이라는 모델명을 다시 사용했습니다.
Climatronic is not working
How to repair clima compressor
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Ac repairs are not DIY friendly due to most diyers unfamiliar with vehicle refrigeration repairs encompassing; tools and equipment needed for correct, safe, removal of refrigerant, determiing what parts need replacing, flushing the system of oil and contaminants if sealer was ever used, replacing oil, replacing old valve cores in both service valves, using new seals everywhere to ensure against leaks from a pressurized system whether operating or not, evacuating a repaired system, final leak test in a vacuum before refilling with new refrigerant. Diyers familiar with ac repairs will use refrigeration gauges to assess system refrigeration capacity in determining whether a leak or compressor damage occurred. As a rule, diyers are not equipped or skilled in repairing ac compressors other than replacing a blown clutch coil along wth new idler pulley and clutch plate. Compressors are replaced in its entirety.
If you are fortunate and a leak hasn't occurred requiring all the aforementioned items to make repairs, this may be as simple as a worn out compressor control valve operated electronically to govern compressor operation; https://www.youtube.com/watch?v=94dRjWG9...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
gas system is ok.
compressor is problem. i will replace control valve, and hope that it will work.
thank you wery much.
의
댓글 달기
답변을 추가하세요
orban orban 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 11
전체 시간: 191
