주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 4월에 발표 및 출시된 2세대 iPhone SE의 수리 및 분해 정보입니다.
Battery dies super quick
It dies so quickly
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Could you elaborate more? As far as I can tell you just need to replace the battery
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Oh no the battery compadity is literally 79 %
의 공유
@thecat847 Yeah that is way too low. At 85 you should replace it
의 공유
It works but I do have a toolbox to take out screws but no way to soften the glue and no replacement battery
의 공유
댓글 달기
Go into your Settings under the battery heading will be the battery health. It's a percentage from 0-100 showing what the current capacity of the battery is vs. how much it should be able to hold. If it's less than about 85%, Apple says it should be replaced.
Over time batteries lose the ability to hold a full charge, so even though it says it's charged to 100%, it may only be holding 2/3rds as much charge as it should, meaning it's going to die in a much shorter time than it used to.
The solution here is to replace the battery. iFixit has a guide showing you step by step how to do that yourself. Note that unless you buy a genuine Apple battery (and have iOS 18 or later), you'll lose the ability to view the battery health information and get a pop-up warning for a week or so that the phone cannot determine if the battery is a genuine apple part. Other than those issues, an aftermarket battery will charge and work normally.
iPhone SE 2020 Battery Replacement - iFixit Repair Guide
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
The cat15 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 207
