주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 7세대 스마트워치, 셀룰러 연결 옵션 포함, 2021년 10월 15일 출시.
Display remains off after replacement
Hey everyone,
A week or so ago I managed to replace the battery on my 41mm series 7. Hurray! Or so I thought.
I initially powered it on without reapplying the screen's adhesive, and unfortunately when reopening it things went wrong and I ended up bending some of the display pins, which resulted in the display not turning on.
I ordered a new display from iFixit, followed the instructions to replace it (disconnecting the battery first), and after putting everything together the display still remains black while the watch is on (I see its battery in iOS and I can mirror its screen with the accessibility settings.
Anything obvious I should look for? I double-checked and the screen connectors seem to be fully in (see images).
이미지
이미지
Additionally, just want to make sure I got this right and the connector with (1)
이미지
should go in-between the taptic engine and what seems to be the housing of the crown? (2)
이미지
Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
On photo it looks like some pins of a LEFT connector on motherboard are still missing. If it is, you have to resolder this connector, it's a very difficult procedure.
Which connector do you mean? I don’t think any pins were lost - only bent - and the photos show the new display.
댓글 달기
답변 1개
@hugo57122 i have the same issue when i replaced the battery. can i enquire did you manage to resolve the issue?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Unfortunately not
댓글 달기
답변을 추가하세요
Hugo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 42
전체 시간: 318
