주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년에 출시된 HP EliteBook 850 G2는 850 G1의 업데이트 모델로, 더 새로운 프로세서와 선택 사양인 터치스크린이 특징입니다. 수리 안내서 및 상세 정보는 여기에서 확인할 수 있습니다.
My device doesnt powering on.
Device doesnt powering on..with battery or without battery, only charger.
When i press power on button,only keyboard lights turn on for a second, not ndisplay.after a second it turns off keyboard light too..
I opened the case.The fan spins when device got power.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
@dynamicrex does the fan spin normal, fast or just a little bit? What have you already checked?
Fast spining fan
Please Remove the RAM and check
@dynamicrex Have you attempted to remove/reinsert the hard drive in addition to the RAM?
댓글 달기
답변 3개
This behavior usually points to a hardware power or motherboard issue. Since the keyboard backlight flashes briefly and the fan spins, the laptop is receiving power but failing POST. Try a hard reset first: unplug charger, remove battery, hold the power button for 30–40 seconds, then retry with charger only. Reseat RAM, SSD, and display cable. Test with one RAM stick if possible. If there’s no display even on an external monitor, the issue is likely a faulty motherboard, BIOS corruption, or power IC. In that case, professional repair or board replacement is required.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Mine did this after the battery died. Wouldn’t turn on with or without the battery, just flashed the keyboard lights. CMOS reset fixed it. Pulled the battery, held power button for ~30 seconds, then tried again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well you can checkout the following video: https://www.youtube.com/watch?v=eHPTNKTg...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dynamic Rex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 133
