์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
2013๋…„์—์„œ 2017๋…„ ์‚ฌ์ด์— ์ƒ์‚ฐ๋œ ThinkCentre M73(์œ ํ˜• 10AX, 10AY) "Tiny ํผ ํŒฉํ„ฐ" ๋ฐ์Šคํฌํ†ฑ์ž…๋‹ˆ๋‹ค.
System error when turned on
My pc shows an error message when turned on about product patents, client Mac address.
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 1๊ฐœ:
cpu fan failure
์˜ ๊ณต์œ
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
  • BIOS/UEFI configuration issue
    • If the system canโ€™t find a valid boot drive, it tries to boot over the network (PXE boot). Thatโ€™s when you see Client MAC address and patent/product messages.
  • Missing/Corrupted DMI (Desktop Management Interface) info
    • Sometimes after a motherboard replacement or BIOS reset, system-specific info (like product number, serial number, etc.) isnโ€™t written to the BIOS properly. HP, Dell, and Lenovo systems often throw โ€œProduct Information Not Validโ€ errors in that case.
  • Hard Drive / Boot Device issue
    • If your storage drive isnโ€™t detected or has failed, the PC skips to network boot.
How to Fix-
  1. Check Boot Order
    • Enter BIOS/UEFI (usually press F2, F10, ESC, or DEL at startup).
    • Ensure your hard drive/SSD is listed as the first boot device, not โ€œNetwork Bootโ€ or PXE.
  2. Reconnect Storage Drive
    • Power off the PC, reseat the HDD/SSD cables (or NVMe drive) to ensure itโ€™s properly connected.
  3. Reset BIOS
    • In BIOS, look for โ€œLoad Optimized Defaultsโ€ or โ€œReset to Defaultsโ€ and save.
  4. Check for DMI/Serial Info
    • If the error mentions product patents or product info not valid, it may require reprogramming the system board information (usually only a service center or manufacturer tool can do this).
  5. Disable PXE Boot
    • If you donโ€™t use network booting, disable PXE/Network Boot from BIOS.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Gaone ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 2
์ง€๋‚œ 7์ผ: 13
์ง€๋‚œ 30์ผ: 50
์ „์ฒด ์‹œ๊ฐ„: 277
