주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ford Super Duty(F-Series Super Duty라고도 함)는 미국 자동차 제조사인 Ford Motor Company에서 생산하는 트럭 시리즈입니다.
How to fix computer code B1317:60
I ran out of fuel without knowing (dashboard doesn't work) on a slope. Tried to crank on and it failed so I leveled the truck the most I could on the road and still nothing. Fueled up 5 gallons and nothing. Had a mechanic bleed out the lines and gave the truck a jump from another truck and it will automatically shut off. So we checked the diagnostic system and it gives me codes B1317:60 ; B1352:60 ; and U1900:60.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hey there, from the codes and what you described, here’s what I think is going on with your truck.
B1317 means your battery voltage is low – could be a weak battery, bad connection, or the alternator not charging right.
B1352 points to a problem with the ignition switch or the wiring around it.
U1900 is a communication issue between the truck’s computer modules – usually wiring or a connector somewhere.
Since you ran out of fuel, it’s also possible there’s still air trapped in the fuel lines. I’d start by making sure the battery’s solid, check the ignition stuff, make sure the wiring/connectors are good, and prime the fuel system.
If it still won’t start after that, you might need a Ford guy to take a closer look, especially with the dash not working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lauro Perez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 33
전체 시간: 356
