주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
소니 PlayStation 5 DualSense 컨트롤러 5세대 모델의 수리 안내서, 분해 정보, 문제해결 정보를 다룹니다. 모델 번호 CFI-ZCT1W와 마더보드 모델 BDM-050으로 식별할 수 있습니다.
Replacing haptic feedback rumble motors?
I've noticed recently after playing a lot of the f1 game, my haptic feedback is just suddenly extremely weak compared to what it used to be. I've tried pretty much everything I think and nothing works, tried enabling the speaker in my sound settings but my controller doesn't even appear in there. I downloaded dualsense x and tested the right side and left side rumble motors by themselves and the right side is significantly weaker. Wanted to know if replacing the rumble motors would be possible on the V5 since I don't already see any guides here and if so is it just the rumble motors that need to be replaced or anything also involving the triggers?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
The process is nearly the same as V2, V1 ect ect.
So you should be able to use the same guide that is created for the V2 or V1.
How is the haptic feedback? Still good? If yes, then you do not need to replace them, but just the rumble motor it self.
Guide: DualSense Controller v2 Vibration Motor Replacement - iFixit Repair Guide
If the haptic feedback buttons are back or got a lot weaker, then I advise to replace them as well.
Guide: DualSense Controller v2 Adaptive Trigger Replacement - iFixit Repair Guide
So far it does look like you just need to replace the rumble motors.
Please let us know if you have any questions!
DualSense Controller v2 적응형 트리거 이미지
안내서
DualSense 컨트롤러 v2 적응형 트리거 교체
난이도:
조정
30 minutes - 1 hour
DualSense Controller v2 진동 모터 이미지
안내서
Sony DualSense v2 진동 모터 교체
난이도:
어려움
1 - 2 hours
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Not muting your mic can override your haptics settings and set them to low or off make sure the button at the bottom is lit orange.
댓글 달기
답변을 추가하세요
brending 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 46
전체 시간: 804
