주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 시리즈의 후속작인 1세대 Sony PlayStation 5 DualSense 컨트롤러에 대한 수리 안내서, 분해도 및 문제해결 정보입니다. 모델 번호 CFI-ZCT1W와 마더보드 모델 BDM-010으로 식별됩니다.
PS5 DualSense Controller Triangle Button Stopped Working
Hi,
My son dropped my controller a few times and all of a sudden the triangle is not working very well. Sometimes it works, sometimes it doesn't. I tried cleaning it up from the outside and I'm a bit sceptical about opening it as I might just make it stop working completely. Does anyone have experienced something like that? R2 trigger is also in the same condition (sometimes it works, sometimes it doesn't).
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi there!
Can you still press them in? How does the button feel? Still "Clickable"?
If not, you might want to clean everything inside (with isopropyl alcohol) and replace the rubber.
Guide: Sony DualSense Controller Buttons Replacement - iFixit Repair Guide (till step 33).
If that doesn't work, then you need to replace the button circuit membrane... There is no guide for it, yet. But you can follow the same guide to get there.
Regarding the R2, try cleaning first! If that doesn't work, then you might want to replace the trigger assembly..
Guide: Sony DualSense Controller Trigger Assembly Replacement - iFixit Repair Guide
Please let us know what worked or not!
DualSense 트리거 어셈블리 이미지
안내서
Sony DualSense 컨트롤러 트리거 어셈블리 교체
난이도:
조정
1 - 2 hours
DualSense 버튼 이미지
안내서
Sony DualSense 컨트롤러 버튼 교체
난이도:
조정
1 - 2 hours
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Hello! Yes, I can still press the button and sometimes it works but for some reason it just stops working now and then.
I will try with your first option and write here if that actually worked or not. Thanks for the tip. Hopefully I won't break it :')
Alright, yes then cleaning would be the first thing to do! Hopefully the controller will remain intact. Good luck with the repair :)!
댓글 달기
답변을 추가하세요
Ricardo MVG 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 24
지난 30일: 90
전체 시간: 1,016
