주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Signature M650 무선 마우스의 수리 안내서, 분해 정보 및 문제 해결입니다. 부품 번호(P/N) 910-006250, 910-006251, 910-006252로 식별됩니다.
Logitech Signature M650 left click not working
Why is the left click on my Logitech Signature M650 mouse not working properly? I have to press it harder than usual or force click for it to register. What could be causing this, and how can I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Had same issue, disassembled and got some WD40 into the switch button works for me.
댓글 달기
답변 3개
가장 유용한 답변
The switch failed. You can find the part on Amazon or AliEx. Search for phrases like:
Silent Mouse Button Switch 6*6*7.3MM Square Microswitch Two Pin
The switch is 7.3mm tall, and 6mm (or 6.2mm) square. You will need a solder sucker or wick, and to remove the board from the shell (4 screws and carefully pry out the battery contacts). The switch is held on by its own 2 pins and is easy to remove.
이미지
Update (11/16/25)
Getting in to the mouse is pretty easy. Start with these two screws inside the battery door. Then gently separate the mouse from the back. There is a clip near the front so you have to kind of slide the bottom forward to release it.
이미지
이미지
Remove the main cable
이미지
Remove 4 screws for the PCB & scroll wheel (scroll wheel comes off separately)
이미지
Remove the battery terminals by gently pulling up the whole PCB. Don't bend or stress the battery wires.
이미지
Use a solder-sucker to remove and then resolder with new switches for the left and right mouse button. .
이미지
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Instead of replacement with non-stock ones, a semi-permanent fix may be to simply exchange the right and left switches (assuming that the left one has worn out way quicker).
댓글 달기
Yup, same problem. Disassembled it. Tried to directly press the button underneath slightly, which is just right for my use - doesn't register. Have to press it harder. The disassembly process is just like M550 (on Youtube), but be careful of the extra twisted wire for LED on the top shell on the M650.
So far, finding the switch for the 'SW1' has been unfruitful. Will update if I find anything.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
There are many on Amazon or AliEx. Search for phrases like:
댓글 달기
이미지
이미지
Thanks for providing the switch specifications! Successfully replaced both switches on my Logitech M650. The disassembly is straightforward and easy. I boght the switches from china, via Shoppee in the Philippines. The left button now registers light clicks perfectly instead of needing heavy force to actuate.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
That's great news! thanks for sharing.
댓글 달기
답변을 추가하세요
Horenus Dessalegn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 63
지난 30일: 375
전체 시간: 2,863
