주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Pro 7세대 비즈니스 모델을 위한 수리 안내서입니다. Surface Pro 7+는 2021년 9월 22일 소비자용으로 처음 공개되었습니다.
Thermal paste on SSD?
The SSD replacement kit contains a tube of thermal paste. Should i really use that? If so: on both sides?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I would use it on the bottom where it contacts the heat sink, but NO, not on the top, where you place the cover plate. don't put much, a very thin layer, spread across where the heat sink, (the metal ring) contacts it. Reasons:
  1. Thermal paste improves heat transfer between the SSD and the heatsink and helps maintain "optimal" operating temperatures.
  2. Thermal paste can reduce the risk of overheating and thus extend the SSD's lifespan.
  3. Clean any old paste or thermal pad that may be present (Q-tip and alcohol) before applying the new paste.
Good Luck!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks. I currently have some thermal (conductive) tape on the bottom (display side). That works fine. It pushes the ssd up just a tiny bit, which presses it against the cover plate. It loses most heat through contact with the cover plate, so it doesn't require anything on top for me. The tape was scraped from an old harddisk enclosure
I might replace the tape with some copper if I'm not afraid of shorts for even better thermal conductivity.
의 공유
PS tape is a lot less messy imho ;-)
의 공유
댓글 달기
답변을 추가하세요
Arend Hamming 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 281
