주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 출시된 Apple의 11" MacBook Air 업데이트 모델은 5세대 Intel Core i5 및 i7 프로세서를 탑재하여 성능과 배터리 사용 시간이 소폭 향상되었습니다.
Trackpad suddenly not clicking
Hi, so I’ve had this laptop for over a decade and I’m determined to keep using it until it literally explodes, so a few weeks ago I got a replacement battery from here & installed it. It’s been great & I haven’t had any issues, but today I went to use it as usual and suddenly my trackpad wasn’t clicking. I could double tap & move the mouse but the actual click sensation is gone. I spent an hour troubleshooting, restarting the computer & reinstalling the battery but the problem persists & diagnostics turns up nothing. Any suggestions would be appreciated, thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
You could try to adjust the small screw that sets the trackpads position located at the lower center of the case (It is hard to miss) to see it that helps, failing that remove the trackpad and give the edges and the case edges a good clean up, then reinstall it. Check also the cable that connects to the logic board, these can become creased or suffer damaged pins quite easily. Trackpads can fail over time so if the first options didn't solve it then it would likely need a fresh trackpad and cable.
이미지
MacBook Air 11" Early 2015 트랙 패드 교체
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks! I messed with the trackpad screw for a few minutes with the display on until I got a tension that worked!
@jets96744 Good to hear :)
댓글 달기
답변을 추가하세요
Jet S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 41
지난 30일: 113
전체 시간: 596
