주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년형 12" Retina MacBook 모델 A1534에 대한 수리 정보 및 안내서
LCD or GPU Issue?
I have here an A1534 1.1 GHz model that has suffered the all to common CPU failure from I guess overheating, which must be common in these fanless Macbooks.... And someone is offering me the same model (But not sure the CPU as 3 versions were made) for next to nothing price, but it comes with this apparent display issue....
이미지
이미지
이미지
I am thinking to just swap over the logic board to make a 'working' unit, but I am concerned that there maybe an irreparable GPU issue other than a faulty display..... to me it looks reminiscent of the scenario when changing the default resolution and then rebooting where these similar lines appear for a split second until the system recognizes the adjusted resolution which to me points to a GPU error as the lines remain as pictured when the system is active.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
it may be a gpu issue on your macbook or some componants going to the gpu got knocked off
의
Can you try it with an external monitor? That should tell you whether it's a GPU or display issue.
의
댓글 달기
답변 1개
선택된 해법
I'm not a MAC person, but the display appears to be functioning and the computer is having a problem. Therefore, my guess would be that the computer can't load the drivers to the GPU and isn't getting a response from the GPU. Therefore, it is likely a GPU issue. If it isn't a plug in part, the MB needs replacing.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yeah these are nice looking MacBooks but TOTALLY useless and prone to MB Issues..... Just a nice ornament.
의
댓글 달기
답변을 추가하세요
livfe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 239
