주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이전 모델의 업데이트 버전으로 2022년에 출시되었습니다. 전년도 Tuf Dash F15보다 우아한 외관과 향상된 성능을 갖추고 있습니다.
Wifi intel driver is down
The wifi driver in my laptop shows and error and it’s not working I tried to update it and deleted it and reinstalled it and nothing helped
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
@laithlakmoush
what error message did you get in device manager?
what os version is your computer running? win 11?
@salmonjapan
Error message: Windows has stopped this device because it has reported problems (code 43)
Win 11 64-bit
댓글 달기
답변 2개
Windows 11 error 43 means a device has reported a problem, often due to driver corruption, outdated drivers, or a hardware malfunction.
If you tried to update drivers via the device manager, that doesn't work very reliably.
For drivers, you might find something here https://www.catalog.update.microsoft.com... or search for "[hardware ID] drivers".
You can find the hardware ID in the Device manager.
If you find a new one delete the old one b4 you try to install the new one.
If that doesn't work, the next step would be to replace the WiFi daughter board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ah yes, the classic ‘I deleted it, reinstalled it, cursed at my laptop, and it still won’t work’ scenario.
Here’s what I’ve learned the hard way: Windows Update is usually wrong about Wi-Fi drivers. Go straight to the manufacturer’s website and get the official driver. Uninstall, reboot, install.
Also, sometimes the Wi-Fi card just wants a nap — check Power Management settings in Device Manager. After I did that, mine came back to life like nothing happened.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Laith Lakmoush 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 189
