주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
''PS2''라고 알려진 이 기기는 2000년 3월 일본에서 Sony가 처음 출시한 6세대 게임기입니다. 미국에서는 같은 해 2000년에 SCPH-30000 모델로 출시되었습니다. 이 기기를 수리하려면 일반적인 도구만 있으면 되지만, 다소 까다로울 수 있습니다.
Fat Ps2 Scratching discs?
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이미지
Typically when discussing Ps2's that scratch discs, the slim is the first thing that comes to mind. I have however recently purchased an SCPH 50001/N model and noticed that mine is scratching discs a bit differently. After having searched many forums, I can not find so much information.
Here's the issue:
I have purchased games recently that were very clean (SCIII and SOE) and decided to pop them into the PS2. What I've noticed is that after 30 mins or so I receive a pattern of hair like circular scratches around the disc. Now keep in mind, these are not circles that ring around the whole disc, rather its a pattern of multiple circles around the disc. What could be causing this? If you need pictures I am able to upload but any help would be appreciated as I can't find anything.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Could be multiple things.
1: The laser is replaced and not correctly installed (in height).
2: The top case has been replaced with another one, but is the incorrect type/version.
3: Disc drive isn't alligned properly (less likely).
4: Something is stuck inside the disc drive causing scratches.
Did you recently repaired the PS2? Or did the previous owner?
Replacing the disc drive is a option, replacing the top case is difficult as there are many versions out there.
If you can share some pictures, that would be great!
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
Hi there! Thank you for engaging with my post. I have just posted the pictures now. Let me know if you have any questions.
의
Hi!
Yes, I would replace the top cover of the disk drive. There are 2 main versions out there.
1: Top loader with 2 clips and 2 screws.
2: Top loader with 4 screws without clips.
You need the 1st one. The one with 2 clips and 2 screws. I would replace that one and see how that goes. If the same issue occurs, I would replace the laser and check afterwards.
Still facing issues? Then you most likely want to replace the whole drive.
Please let us know how it goes!
의
@dan0 Thank You. Just out of curiosity, do you see any issues with the top loader itself which causes you to suggest that?
의
My pleasure! No I don't. It's hard to see with the eye. I know from experience that the top loader is usually the culprit..
의
@dan0 Ok! I really appreciate your help!
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Tom19 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 58
전체 시간: 855
