์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
Logitech G305 ๋ฌด์„  ๊ฒŒ์ด๋ฐ ๋งˆ์šฐ์Šค์— ๋Œ€ํ•œ ์ˆ˜๋ฆฌ ๋ฐ ๋ถ„ํ•ด ์ •๋ณด์ž…๋‹ˆ๋‹ค. ๋ชจ๋ธ ๋ฒˆํ˜ธ M-R0071๋กœ ์‹๋ณ„ํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค. 2018๋…„ 5์›”์— ์ถœ์‹œ๋˜์—ˆ์Šต๋‹ˆ๋‹ค.
Mouse sensor seems to have broken
My G305 has been working pretty much perfectly for the past 2-3 years but I went away for a few days and now I've come back and the sensor seems to be dead. The battery is new and the lights on the mouse work and aren't flashing red like they usually do when the battery is low but the infrared sensor light is gone. I really like the mouse and it was pretty expensive for my budget so I don't want to have to replace it bc I wouldn't be able to get another 305 so I wanted to know if there was anything I haven't thought of to fix it before I try taking it apart.
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
This usually points toย sensor-level failureย orย firmware/power issuesย rather than something simple like a low battery. Test on Another Computer/Surface, Reset the Mouse, Re-pair the Wireless Dongle
Sensor-Specific Troubleshooting
๐Ÿ”น Infrared Sensor Light
  • The sensor usesย IR illumination, which is invisible to the naked eye.
  • If you seeย no faint glow at allย under a phone camera (IR can sometimes show up), it may indicate aย dead sensorย orย no power delivery to the sensor.
๐Ÿ”น Internal Contact Issue
  • The G305 is fairly robust, but battery movement, humidity, or shock can loosen theย tiny contacts connecting the sensor to the PCB.
  • If the mouse has been stored somewhere it could have gotten warm, cold, or damp,ย the sensor might not be getting voltage.
If All Else Fails: Internal Inspection
Important:ย Opening the G305 will void warranty (though after 2โ€“3 years, thatโ€™s probably not a concern).
Things to check internally:
  1. Remove the shell carefully.
  2. Look forย burnt or discolored componentsย around the sensor.
  3. Check theย sensor flex or PCB solder jointsย โ€” sometimes aย tiny crackย can appear, cutting power.
  4. If youโ€™re lucky, itโ€™s just aย loose ribbon or solder joint, which can be reflowed with very light soldering.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 1๊ฐœ:
There's a faint bluish-purple light coming from the sensor under a phone camera, does this mean the issue is with something else in the mouse? I've tried it on a laptop and it still didn't work so I'm confident it's not my PC
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Amity Gildersleeve ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 3
์ง€๋‚œ 7์ผ: 13
์ง€๋‚œ 30์ผ: 74
์ „์ฒด ์‹œ๊ฐ„: 634
