주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Date time are not
Replacing the cimos battary
And over heating issue
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
What do you mean? Are you asking if you need to replace the CMOS battery or did you and now the date and time are not correct?
What is the date and time showing, and then after you set it and turn the system off and back on is it what you set or back to the wrong one you had just altered it from?
의 공유
댓글 달기
답변 1개
An over heating system can be as simple as clogged fan and heatsink so the system can't cool its self. It is also possible the battery is failing and needs replacing.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joy Deb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 167
