How do I fix the touchscreen?
I was messing in my chromebook and now the buttom of the screen is overheating to the point where the plastic melts on the front and back and the touch screen doesn't work.
좋은 질문입니까?
좋은 질문입니까?
If the machine turns on with an external display (AND isolated to the LCD), the machine is probably fine, but the LCD assembly is damaged, or you blew the LCD fuse :-(. Get a DMM and check for a fuse around the iDP connector—it's usually labeled with an F at the beginning. Measure it in continuity, if your meter beeps, the fuse is good, but the LCD is blown.
Sadly, the issue with Chromebooks (and why I disdain them, especially in schools) is that the cost of parts vs. replacement is always at least 50-60% of the cost of a new one - repair is possible, but they are usually BER way more often than not. Sometimes you get lucky and find an MDM-locked donor with what you need, but a lot of those come from schools and tend to be trashed to such an extent that they're awful donor machines since the schools charge the student for the Chromebook, replace it, and recycle it with the MDM because they ALWAYS forget to remove it. Not all of them are worth more dead, but it's like a 70/30 dud to working unit ratio. I wouldn't buy them to refurbish given the high MDM remains rate, but as donors? As long as they're not run over and glued several ways to Sunday, I'll buy them to do shell swaps or pull what I need to fix the other unit - as long as the AUE policy is still active for 3-4 years.
이 답변이 도움이 되었나요?
Thank you so so much for this it has really helped
@matthewdevoll This one may not be so bad - ~$50 buys you a used LCD assembly on eBay, but if you can get the seller down a few bucks it just barely avoids the infamous 50-60% death sentence given these sell for $80-100. Lenovo FRU is unknown, but search this on eBay: Lenovo 500e 3rd Gen 3 G3 Chromebook 11.6" Touchscreen LCD
지난 24시간: 1
지난 7일: 10
지난 30일: 33
전체 시간: 364
댓글 7개
@matthewdevoll tell us more about the "messing in my chromebook" part. What did you do and where did you do it :-)?
oldturkey03 의
sorry i should have clarified
I was just looking around inside unplugging a couple things to see what changed (was not a good idea) and once i forgot to unplug battery and when i turned it back on and the touchscreen didn't work. I did some research and thought "oh ok not a big deal". then I noticed the plastic at the bottom started melting on the front and back and now it wont turn on.
Matthew DeVoll 의
@matthewdevoll something got shorted out. Take some good pictures of the things you unplugged and of the damaged area. Let's see what this all looks like. 기존 질문에 이미지 추가하기
oldturkey03 의
Once i get it back will do
but for now a guy has it
Matthew DeVoll 의
Thanks so much!
Matthew DeVoll 의
댓글 2개 더보기
