주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 설계한 M2 Pro 및 M2 Max SoC를 탑재하고 2023년 1월에 출시된 14-인치 MacBook Pro의 수리 안내서 및 분해 정보입니다.
Battery replaced not working
I have a a2779 MacBook Pro , I started getting a service battery warning last week and when I run out of power the mag safe started flashing orange and did not charge , I ordered a replacement off I fix it for the model, I fitted it this morning and when I plug the mag safe in now with the new battery installed I get no light and it does seem to charge, I tried to charge via usb c left it charging for 1 hour but nothing, can anyone help? Thanks in advance
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
A common issue is forgetting to set the ZIF latch from the Battery board or the cable./connector is damaged. Review Step 7 ~ 9 MacBook Pro 14" Early 2023 배터리 교체 here is the referee making sure the latch is not set, sliding in squarely the ribbon cable and carefully setting the latch so it's grabbed. Also check the battery side connection as well.
If the cable is damaged you'll need a replacement MacBook Pro 14" BMU Flex Cable - Apple P/N 923-08652
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joedee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 196
