주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Valve에서 2023년에 새롭게 출시한 인기 휴대용 게임기인 Steam Deck OLED의 수리, 분해 및 문제해결 정보입니다. 2023년 11월 16일에 출시되었습니다. 모델 번호 1030으로 식별됩니다.
Steam deck Battery Health
When I got my Steam deck about a year ago, I would get 8-9 hours in half life 2 and 2.5 hours in cyberpunk 2077, now I get around 6.5-7 hours in half life 2, and 2 hours in cyberpunk, should I replace my battery soon, or wait a bit to replace it, the system still says its at 100% percent health but I don't believe that number entirely.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
could be dried thermal paste causing the CPU temperature to rise and requiring higher fan rpm to cool the console, drawing more power and decreasing battery life. Does your Steam deck feel hot when gaming?
의
Not really, if sits around 65-70 degrees when playing a really heavy game like cyberpunk
의
댓글 달기
답변 1개
선택된 해법
You probably shouldn't replace your battery right now. All battery age, but if there's only about an hour's difference in battery life compared to when it's new, replacing the battery now would be a waste. A new battery's both expensive and pretty hard to replace if it's your first time fixing stuff. If it works, it works. Wait until the battery life's significantly short or when it starts to bother you a lot, then replace it.
However, if you're really paranoid about battery life or feel like you'd like a few more minutes of cyberpunk, here's the guide.
Steam Deck OLED Battery Replacement
A lot of glue and fragile cables, so make sure you follow the steps carefully. It would be a good idea to read the guide before you actually start to replace it, to get a general idea of the steps.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
That's what I thought as well, I've repaired adhesive batteries before, but I agree that I should probably wait to replace it.
의
댓글 달기
답변을 추가하세요
Caleb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 12
지난 7일: 56
지난 30일: 238
전체 시간: 3,151
