주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 AirPods(3세대) 무선 이어버드에 대한 수리 및 분해 정보입니다.
Sound loss on one side
For example, the right side operates loudly and the left side operates quietly.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
If you can hear through it the sound duct is clogged with junk! Just dampen a Cotton Q-Tip with some isopropyl alcohol (not wet!) and carefully clean in stages the duct port, you should not need to enter, if you do you do risk pushing the junk into the sound chamber.
Here's a guide someone wrote up AirPods 3 정밀 세척 방법 (이어버드 전용) scraping off the big stuff makes sense. Mine don't have any screen unlike these.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The single-side quietness on AirPods 3 almost always comes down to one of three things: (1) the sound duct/mesh on the quiet bud is clogged with earwax or dust — the cleaning answer above is the right first step; (2) the balance slider got bumped — check Settings > Accessibility > Audio/Visual and make sure Balance is centered; (3) a degraded ear-tip seal. Quick test: swap the tips between buds — if the quietness moves with the tip, it's fit, not the driver. If cleaning plus balance doesn't bring the left side back, these AirPods quiet fixes (https://fixmyphonespeaker.com/blog/why-a...) walk through the remaining checks (mono test tracks, reset procedure, when it's actually a dead driver). (Disclosure: I help build FixMyPhoneSpeaker.)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Soufiane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 52
전체 시간: 222
