How to fix my wire sensor
can please guide me on how to replace the sensor that activates the earbuds on and off
좋은 질문입니까?
좋은 질문입니까?
It sounds like your wire sensor issue is likely caused by a loose connection or internal break, which is pretty common over time. Starting with a careful visual check for damaged spots or bent pins can save you a lot of guesswork. If everything looks fine, testing continuity with a simple multimeter usually helps pinpoint the fault. I’ve had similar problems while working on small device repairs for mesolyft.com projects, and a clean reconnection or replacing the damaged segment often did the trick. If none of that works, the sensor itself may just need replacing.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 12
지난 30일: 32
전체 시간: 181
