Why does the screen go black
when the hdmi cable is connected and the console is on (xbox one), the screen turns black for around 5-10 seconds and then returns, what is the cause of it
i have some initial thought of why, but i need others opinion and also do i need the correct hdmi port for the right console or does this not matter in the same manner as the cooling fan and heat sync
좋은 질문입니까?
댓글 2개
Hi! Is this repeating all the time? Did you tried another HDMI cable and TV?
koppie007 의 공유
@dan0 it is temporarily resolved but it will continue to go black and it is not the cable as this has been switched out and still does it
it is also loose when inserted into the port so am guessing am gonna have to swap out the hdmi port with a replacement but does it matter if it is not the same as the original or does it need to be the precise same as the original as it is only a port and not a disc drive or power board
Matt 의 공유
