주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2023년 1월에 출시된 13세대 Intel H 시리즈 프로세서를 탑재했으며, RTX 3050 4GB 모델로도 제공됩니다. 알루미늄 및 마그네슘 섀시와 14.5인치 2880x1800 OLED 디스플레이를 갖추고 있으며, 모델 번호 UX3404로 식별됩니다.
Flickering screen repair steps
The screen of the laptop is flickering. I was recommended to change the screen. Is it repairable
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
who recommended replacing screen? The flickering can be caused by many problems. Screen replacement would be the last option.
First open a CMD prompt window and run chkdsk c:
Then open a CMD prompt window as admin and run scf /scannow
Then look for the lasted driver for your video system and install that.
Now, if you have a video port on the laptop, try connecting an external monitor. If that doesn't work, it is likely a problem on the MB.
If you got this far without solving the problem and the external monitor worked, open the laptop and disconnect and reconnect the screen cables - search for how to open the connectors and be careful as the are fragile.
If the problem still exists, now you can consider if it is economically feasible to replace the screen or buy a new computer.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Micro center’s repair tech recommended replacing the screen. I have tried your suggestion, the problem persist but the computer works with an external screen.
댓글 달기
답변을 추가하세요
Babacar Faye 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 51
전체 시간: 479
