주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Right joycon doesn't connect wirelessly
Hello
my right joycon works only when attached on the switch but does not connect wirelessly when taken off, the switch doesn't even recognize it.
It is not an antenna issue, i've already tried replacing it, its not a switch issue as it works with other joycons, the joycon (that doesn't work) doesn't connect wirelessly to any switch i've tried it.
From reading i suspect it being a problem from the bluetooth chip on the motherboard, any suggestions?
edit: I've tried connecting the right joycon to my phone via bluetooth and it doesn't show up but trying with the left one it does show up
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi!
In this case it does sound like a issue with the bluetooth chip. So replacing that chip will most likely solve it. Soldering is required for this.
I would just replace the motherboard. You can buy them on Ifixit when it’s in stock. Otherwise you can try AliExpress. They are not that expensive, so it’s worth it in my opinion.
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
took a long time to get the replacement part, but in the end it works now after replacing the motherboard
의
Alright! Good to hear that it is fixed anyway now :)!
Have a great day!
의
댓글 달기
답변을 추가하세요
Astronyu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 23
전체 시간: 366
