주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2020년 최고급 스마트폰. 10월 13일에 발표되어 11월 13일에 출시된 iPhone 12 Pro Max는 6.7형 OLED 디스플레이, LiDAR가 탑재된 트리플 후면 카메라 시스템, 5G 연결성을 자랑합니다. iPhone 11 Pro Max의 후속 제품입니다.
NAND Upgrade on iPhone 12 Pro Max
Hi everyone,
I’m working on a iPhone 12 Pro Max board and need to upgrade NAND storage.
The question is:
When replacing the NAND on this model, is it mandatory to use a software tool like U3Tools (or similar) to reprogram/initialize the new chip?
If so, what is the correct procedure after installing the new NAND?
Should I read before the data on the original NAND chip and then paste it on the new one after?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Most shops use a mill to grind down the old NAND chip as it's safer and less trauma to the logic board. As you can see in this YouTube vid iPhone 12 Pro upgrade storage capacity SSD Nand from 128GB to 512GB
And yes you do need to setup the NAND chip using Apples DFU method or U3Tools. If the persons data is important you do need to make a back up. As it sounds like you've never done this I would recommend finding someone who has done a few as it's not that easy! Or at least try out on your own phone you don't care about as there's a strong chance the first one will fail.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Giuseppe Greco 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 30
전체 시간: 357
