주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
Single Graphic Vs Dual Graphic Display Assembly
@danj I have a 2.8 GHz 2015 DG with a faulty display & have found a single graphic 2.8 GHz 2015 model with a good display for cheaper then a replacement Assembly with a 1TB SSD & a near new battery that has just 9 cycles for under $160! I cannot find any info to suggest there is any difference or compatibility issue in swapping over the complete display assembly's. @danj I think your extremely familiar with these as you use one yourself. Need confirmation before I take the plunge and purchase it.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
They both use the same screen. It's easy to verify using TheBookYard listings as an example Parts for Apple MacBook Pro 15" Mid 2015
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
Yes I thought they were the exact same also but just needed confirmation thanks.
의
Out of curiosity what would make the AMD Graphic kick into action? IF gaming, playing a video, High resolution pictures, external display? I found this video https://www.youtube.com/watch?v=KtpZF22H...
의
@livfe - The App requests it as the preferred option. This is part of the Apps code framework. There really isn't a need to alter the display setting from a user perspective. If that was needed that would be a crappy App to have not have the setting set, or someone coding an App who needed to see the difference.
의
@danj Yes, I didn't play with anything from this video, just curious what causes it to switch from Intel to AMD.
의
@livfe - Don't press the Red Button! 😂🤣😂🤣😂🤣
의
댓글 달기
답변을 추가하세요
livfe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 159
