주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 7월 출시, 15" MacBook Pro, 모델 A1990, True Tone 기술이 적용된 15.4인치 LED-백라이트 디스플레이, TouchID, 및 최대 6코어 Core i9 프로세서를 탑재했습니다.
Topcase Replacement Issues - Wont display
Hi all,
I had to replace my top case on my 2018 MacBook Pro 15 inch (A1990). I worked through everything slowly and purposefully. When I tried to turn it on it wouldnt turn on. Then I connected the mains power adaptor and it fired up, I heard the chime but nothing on the display. The Touch Bar lit up and I could increase the volume and decrease but nothing else. Now I cant turn the unit off.
Can anyone shed any light on what might have gone wrong with the procedure or what I need to do to get it up and running again!
Many thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Why did you replace the top case? Do you mean the display lid part or the uppercase keyboard part?
의
It was the keyboard part DanJ
의
@mansoorahm23124 - OK, did you have a liquid spill of some sort?
의
No, some of the keys were missing so thought of replacing the keyboard. Unfortuantely, that meant replacing the topcase in its entirety!
의
댓글 달기
답변 1개
I would look at the guides and check that the LCD cable is connected and also the battery connection. IF still no improvement then prehaps @danj can give some more insight.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mansoor Ahmed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 17
전체 시간: 197
