주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volkswagen Passat B6 및 B7 버전은 독일 자동차 제조사인 Volkswagen에서 생산한 전륜 엔진 대형 패밀리카입니다. Passat B6 라인은 2005년에서 2010년 사이에 생산되었으며, B7 라인은 B6 라인의 페이스리프트 모델로 2010년에서 2015년 사이에 생산되었습니다.
2012 VW Passat 2.0TDI P0299 code
  • How to troubleshoot a PO299 code on a 2012 Volkswagen Passat 2.0 TDI
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The Volkswagen Passat P0299 code indicates a turbocharger underboost condition, meaning the turbo isn't producing the expected boost pressure. This is often caused by leaks in the air intake system, such as a faulty intercooler or boost hoses, or problems with the turbo's wastegate actuator or a sticking wastegate itself. Symptoms include a loss of engine power, reduced acceleration, and the vehicle entering "limp mode".
Common causes
Boost leaks: These can occur in the air intake system, including cracks or loose connections in the boost hoses, intercooler, or the turbo-to-engine manifold.
Wastegate issues: The wastegate controls how much exhaust gas bypasses the turbo. If the wastegate is stuck open or the actuator is failing, it will cause a lack of boost.
Faulty turbocharger actuator: This is a common problem on many Volkswagen Passats, especially the TDI models, and can be caused by a failing vacuum diaphragm or leaking vacuum lines.
Other turbo issues: The turbo itself may have mechanical problems, such as a binding or worn compressor wheel, which can lead to underboost.
Intake restrictions: A very dirty air filter or a clogged intercooler can also restrict airflow enough to trigger the code.
Faulty sensors: A problem with a sensor in the boost pressure system, like a faulty MAP or boost pressure sensor, can also cause the ECU to register an underboost condition.
How to fix:
Inspect for leaks: Start with the most common and cheapest fix. Visually inspect all boost and vacuum hoses for cracks, loose connections, or signs of oil soaking.
Check the wastegate actuator: Look for any visible damage to the diaphragm or actuator rod. Use a vacuum gauge to test for proper operation, as described in the JustAnswer article.
Test the turbo: If leaks are ruled out, have a mechanic inspect the turbo itself to check for proper movement of the wastegate and compressor wheel.
Check other components: If all else fails, check the air filter, intercooler, and relevant sensors for faults.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Exfiremek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 30
지난 30일: 104
전체 시간: 1,267
