주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
problems with hinge/spine of 2ds?
so when i try to move the top screen of my new 2ds backwards after repairing and swapping the shell it doesnt close fully on the back and has trouble when i try to put the top screen flat in line with the bottom ive tried opening and cleaning it i also reseated the top lcd
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This usually happens when the hinge isn’t aligned correctly after the shell swap. Even if the screen and LCD are re-seated, the top housing won’t close or sit flat if:
1. The hinge barrel isn’t fully rotated into its locked position.
It needs to “click” into place. If it’s off even a little, the lid will resist closing.
2. The ribbon cable has tension or is twisting inside the hinge tunnel.
A slight twist is enough to keep the top shell from lining up.
3. One of the hinge tabs isn’t sitting in the shell track.
The system will close on one side but not the other.
Quick fix:
Open the system back up, rotate the hinge fully until it locks, check that the ribbon sits smoothly with no sharp bends, and then reassemble.
No new parts needed unless the hinge barrel is cracked.
If you want, I can tell you exactly how to check alignment step-by-step.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
that would be nice thanks
댓글 달기
답변을 추가하세요
God o 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 57
전체 시간: 539
