주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Green screen without any damage at all
For some reason one day my screen had a green line out of nowhere didn't took it that serious then some days later as I was using it 80% of the screen became green as well but u can still see it normally just that now it has a green tone
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
@luisalejandro sounds like an issue with your LCD screen. Connect an external monitor and let us know if that displays correctly. If so, then the issue is most likely your LCD screen. Yes, this can happen from one minute to the next without any prior warning sign.
의
@oldturkey03 I already plugged in an external monitor and no signs of the green it's also not just a block of green u can still see image on it still
의
@luisalejandro Does the angle that the lid is open have any effect on the green tint? That would indicate a flex/cabling issue.
의
댓글 달기
답변 1개
가장 유용한 답변
You'll want to determine if it's the display itself or your GPU that's at fault here. The easiest way to do that is to plug in an external monitor. If the monitor exhibits the same symptoms, your GPU is having issues; if not, you may need to replace the screen.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Luis Alejandro 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 172
