주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 메인스트림 2021년형 iPhone은 9월 24일에 출시되었으며 6.1인치 OLED 디스플레이, 듀얼 1200만 화소 카메라 시스템, 5가지 색상으로 제공됩니다. iPhone 12의 후속 제품입니다.
How to apply the Display Assembly Adhesive
I noticed that there are no instructions indicating how the adhesive should be applied. Is it pre-cut? Do I need any additional materials besides the adhesive itself? At what stage should it be applied?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
While you can use a liquid or gel-type glue, the pre-cut adhesive available here and elsewhere are recommended, as they are made to fit exactly on your phone and will provide a modicum of water resistance when applied properly.
If you read carefully on the iPhone 13 Screen Replacement guide, you'll find that Step 26 specifically mentions replacing the adhesive and gives a link to a page showing you how. Here's the adhesive page.
iPhone Display Adhesive Replacement - iFixit Repair Guide
You haven't mentioned what repair you're doing that requires you to remove the screen, but typically you'll install the adhesive just before you reconnect the display. Depending on the battery connector, you may need to plug it in as you install the adhesive so the backing sheet will lay flat on the phone as you press down the edges; if you do, be sure to unplug it again before proceeding to connect the screen.
If you haven't installed screen adhesive before, I might suggest you buy a couple of sheets of the precut adhesive. That stuff is not forgiving at all, so if it doesn't go on correctly the first time, you don't get a second chance; if you're like me you'll just end up with a tangled ball of glue. Having a spare on hand would mean you won't have to wait for a reorder to arrive before you can put your phone back together.
iPhone 디스플레이 접착제 이미지
안내서
iPhone 디스플레이 접착제 교체
난이도:
조정
1 hour
iPhone 13 스크린 이미지
안내서
iPhone 13 화면 교체
난이도:
조정
1 - 2 hours
이 답변이 도움이 되었나요?
점수 3
댓글 달기
There is an official guide from Apple, no need to reinvent the wheel here.
https://support.apple.com/en-us/100408
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Marco Baldassarri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 104
