주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Frigidaire 식기세척기 수리 및 문제해결 설명서.
Frigidaire dishwasher making nois
My dishwasher makes noise at the start of the wash cycle but not during the whole wash cycle . Still does a good job cleaning the dishes wondering if its the motor or the pump
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@rob58184 what exact model number is your dishwasher?
댓글 달기
답변 1개
Sounds like it could be something small stuck around the pump area or maybe the circulation motor starting to wear a bit. I had a dishwasher do something similar where it would make a grinding noise for the first minute, and it ended up being debris down in the sump. Since yours is still washing dishes properly, I probably wouldn’t panic yet, but I’d check the filter and underneath the spray arm for any bits of glass or food buildup. Might be worth listening closely to see if it sounds more like a buzz, squeal, or grinding noise since that can usually point you in the right direction. Hope you get it figured out without needing any major repair.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 30
전체 시간: 145
