only OOOOFEOO on the screen
the only thing that appears on the screen is the code OOOOFEOO; nothing works except the power botton.
좋은 질문입니까?
Well, you're certainly in for a ride. What you have here is a Stage 1 bootloader failure. For whatever reason, the bootloader can't communicate with the NAND chip, so it throws that error code.
First off, restore a NAND backup if you can. I'd be surprised if it helped, but hey, you can't really make it any worse. ;)
I'm not really familiar enough with the DSi to offer much advice beyond that, so assuming you've tried dinoo's suggestion, your best bet is probably to ask either the Nintendo Homebrew discord or the DS(i) Mode Hacking discord. Good luck!
이 답변이 도움이 되었나요?
Check the possible solutions given here:
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 265
댓글 4개
Hi @darthmango !
Is this related to a softmod?
Thanks!
koppie007 의
@dan0 Hi! I can't know that without knowing how it happened.
@qntin0k8pkjwtdx Can you shed some light on that for us? How did this start, and is the DS hacked?
darth mango 의
Hi @darthmango !
Alright, fair enough haha :).
Thanks for looking into it!
koppie007 의
hi, thank you both for responding
@darthmango, yes the DS is hacked. this is the first time that a ds that i hacked don't work so i don't really know what happend.
It worked perfectly, but just days before the black screen appeared, it took too long to start up.
배조소 의
