주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Laptop에 대한 수리 매뉴얼 및 정보입니다.
Charger doesn't work all the time.
I recently got a Surface 39w charger from my friend since I've been relying on USB-C chargers, my charger only works sometimes and I don't know why it's doing that because it worked for my friends Surface Laptop.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Your 39W Surface charger (likely the magnetic Surface Connect type for older Surface Laptop models like Go, Laptop 1-4, or similar) having intermittent charging issues is a common problem reported by many Surface users. Since it worked reliably on your friend's device but not consistently on yours, the charger itself might have developed wear (e.g., internal cable strain near the magnetic connector, dirty contacts, or a tripped protection circuit), or there could be a minor issue with your device's port.
A known weak point in older Surface magnetic chargers due to cable strain or design. Since it worked on your friend's device, test it back on theirs if possible to confirm. Replacement genuine Microsoft 39W chargers are available, or consider a higher-wattage official one or a good third-party USB-C PD option for more reliability going forward.
If your device is still under warranty or you need further help, check Microsoft's support site for service options.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
WSOTTC YT 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 75
