주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dishwasher won't start; start button blinks 3 times then turns off
My Whirlpool dishwasher (WDF520PADM7, about 6 years old) will not start. I press the start button, it blinks 3 times, then turns off. I have turned off the circuit breaker for 10 minutes or so, hoping this will reset the machine, but no change. I have run the 123-123-123 diagnostic, all the lights on the control panel light up, but the machine does not run through the testing protocol. I have checked the latch and it seems to be a tight fit. The control lock is not on. Do you have any suggestions as to what else I can try for a DIY fix? Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @anita47514
The door latch might be tight but this doesn't mean that the door latch switch is working OK electrically.
If you have a DMM (digital multimeter) you could disconnect the power to the dishwasher and then access the door latch and use the meter's Ommeter function to check if the latch switch is working OK electrically or not..
Here's a video that shows how to access the latch assembly that will help.
On p.4 of the tech sheet there's a strip diagram showing the door switch circuit.
If the switch is faulty search online for WPW10653840 to find suppliers that suit you best. (examples only)
Secures the dishwasher door in a closed position during operation. 이미지
제품
Whirlpool Dishwasher Door Latch Assembly - WPW10653840
$25.99
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Anita 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 156
