주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 Sony PlayStation 5 DualSense 컨트롤러에 대한 수리 안내서, 분해 정보 및 문제해결 정보입니다. 모델 번호 CFI-ZCT1W 및 마더보드 모델 BDM-030으로 식별할 수 있습니다.
Adaptive Trigger Auto Trigger
I was just finished installing the Hall effect on the controller, and they work fine. However, the trigger motor for adaptive triggers on R2 activates on its own. I disconnected the flex cable, but it still triggers. It doesn't seem to be the springs or anything as the triggers work and they retract, just that the triggers just activate to like a resisting gun trigger every 4-ish seconds. Its seems to be software-related. An y Fixes other than disconnecting the wires?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Hi!
What does gamepad tester says? Also that it's pressed in? Is the firmware up to date? How are the traces? Are none of them are damaged during soldering?
Thanks!
의 공유
The traces are fine now the auto clicking stopped but when I use the https://ds.daidr.me/ Dualsense Tester the Triggers only go into resistance. The auto trigger mode does the same thing as resistance. The Only trace that was accidently torn isnt even related to that. Im fine without the adaptive triggers but my mute button doesnt work
의 공유
gamepad tester says normal, btw
Its not pressing in on its own, its just the adaptive triggers. Firmware is latest
의 공유
Hmm, can you share some pictures with us regarding the motherboard and it's traces? Then we can take a look at it! Hopefully that is OK :)!
Thanks!
의 공유
댓글 달기
답변 1개
Check button for firmware reset.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Elvin Eve 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 8
지난 30일: 45
전체 시간: 297
