주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
POCO X3 NFC Android 스마트폰(모델명 M2007J20CG)에 대한 수리, 분해 및 문제해결 정보를 제공합니다. 스냅드래곤 732G 프로세서, 120 Hz 디스플레이, 64 MP 쿼드 카메라, NFC 및 5160 mAh 배터리를 탑재하고 있습니다.
Volume button not working
Volume Button not working
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
선택된 해법
You'll have to figure out whether the problem is with the physical button on the side of the phone that you press, or the tiny electrical switch mounted on a flex cable inside the phone.
If it's the button, the only way I'm aware of to repair or replace it would be to replace the midframe, as they all come with the buttons already installed. Unfortunately, there don't seem to be any midframe guides available, but the preferred way to replace the screen is to replace the screen+midframe as a single assembly, and there are guides for that. This guide will show you how to do that kind of screen replacement; once you've finished the guide you'll have just the screen+midframe assembly left.
Manuales / Poco X3 NFC / Fullscreen - Nadie Me Llama Gallina
Once you get that far, you can use the iFixit guide for the X3 Pro to remove the screen from the midframe, allowing you to replace the midframe by itself. Just start on Step 17 where you peel up the display connector, then follow the rest of the guide to take off the screen.
Poco X3 Pro Screen Replacement - iFixit Repair Guide
It appears that the X3, the X3 NFC and the X3 Pro all use the same midframe, so these guides should give you all the information you need.
If, on the other hand, the problem is with the internal flex cable and the electrical switch mounted on it, you'll need a different guide showing you how to replace just that part. This guide should be just what you need.
Manuales / Poco X3 NFC / Side push buttons - Nadie Me Llama Gallina
Update (08/31/26)
Unfortunately, the Nadie Me Llama Gallina site appears to have been taken over and taken down, so the previous link to their repair guide is no longer usable.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Trishan Biswas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 23
지난 30일: 76
전체 시간: 614
