Left button not working
The left button intermittently works and has been getting progressively worse over time. Should I follow the disassembly steps as described to replace the battery and try and clean the buttons with compressed air?
좋은 질문입니까?
좋은 질문입니까?
Hi @mcfb, if the Logitech MX Anywhere 3S is still under warranty, I recommend sending it in for repair. Based on my experience, once the warranty has expired the usual fix is replacing the microswitch. The part commonly used is an Omron D2FC-F-7N or similar, which requires desoldering the old switch and soldering in the new one.
이 답변이 도움이 되었나요?
Thanks @augustine, I'm chasing warranty - I'll see how that goes first. Thanks for the help.
Is this a common problem with this model?
I have the same problem with left click, i'm going to try to repair the button. (Tape was not the issue, it was 100% the button malfunctioning)
This can't be true, those switches are substantially larger than the ones present in the MX Anywhere 3S
지난 24시간: 12
지난 7일: 44
지난 30일: 181
전체 시간: 1,334
