주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Buick Century의 마지막 세대는 1997년형 모델을 위해 1996년 후반에 출시되었습니다.
Rear running lights don't work
I just discovered this evening that my rear lights do not work. My brake lights work when I activate the brakes but when my foot comes off the brake pedal all the back lights are off. I've checked all the fuses. I've checked some relays you can't seem to find any reason why the lights won't function
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @anthonymar76475
Have you checked that the fuse that supplies power for the taillights etc is tight in the fuse holder in the fuse block?
If all the lamps aren't working you need to start checking the 12V from the fuse block fuse¹ to the taillights etc and check how far you get before it's not there. The earth to the tail lamps must be OK because you said that the brake lights work and they connect to the same earth (for each taillight)
Here's an image from the 2002 Buick Century service manual showing the wiring for all the lamps that will help.
Since no lights are working it may be a faulty wire or connection between the fuse and the multiple connection point S408 as this is where it splits to go to the left & right sides and the license plates lights etc
¹ In the 2002 model it is fuse #17 in the instrument panel fuse block
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Anthony Marino 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 27
전체 시간: 192
