주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년에 RIDGID에서 제조한 18V 리튬 이온 2단 드릴/드라이버입니다.
How do I remove the chuck for replacement
I have removed the Phillips head screw, but all the instruction I find online, call for a torx head screw once the phillips head screw is removed. My model does not have that. is the chuck screwed on with internal threads or is it a press fit? Any help would be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
You’ll want to open the chick all the way so you can see inside it. Once that’s done you can see what type of driver you need my dewalt uses Allen key. Now here’s the important part the threads are reversed turn right to loosen the chuck. And no you can’t use the drills own power to do that. You need to hold the base while you turn it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 6
지난 30일: 25
전체 시간: 149
