Water temperature not correct
Why my coolant not getting to right temperature
좋은 질문입니까?
Scan it for codes and come back with that. That being said there are a few immediate checks you can do.
First thing I would do is just to be safe, I would do a head gasket test to make sure the coolant isn't leaking - it's usually not the gasket, but once these old GMs get up there in age, a lot of them need head gaskets and if you are having temp issues, it's worth testing. Get a kit like this: https://www.amazon.com/RELD-Gasket-Teste...
The next thing I would do is replace the thermostat -- the part number I found is GM 12622410 and it can be found here: https://www.gmpartsgiant.com/parts/gm-th... -- don't use a aftermarket one, even a good one like a Doorman part. Too sensitive. This code means the thermostat is bad: P0128
The other thing I sometimes know occurs on these "Old GM" vehicles is oftentimes the cluster fails, but the engine portion is fine -- sometimes it can be rebuilt, but often you need to replace the cluster -- you will need a scan tool which can program the mileage once you replace it so it matches so you do not have a "not actual" mark on your title, but if your state doesn't check after 10 years you will want to write the mileage it was replaced at and if you ever sell the car, you need to mention that the cluster is replaced. I have looked into it and it seems like these pull from the ECU, so you may not need to program it, but keep that in mind. GM part number is 16256936.
To provide context why I said "Old GM", especially if you are too young to remember the 2007/2008 GFC: In 2008, the Obama administration gave GM a stimulus, but made them clean up their books, stop wasting money and forced them to hit agressive emissions goals -- that's why anything after 2008+ is not as bulletptoof as the old GMT800/GMT400 and the passenger cars pre-2008. New GM is not the same as Old GM which was famous for 500k mile DuraMax GMT800 with Allison transmissions diesels which run like they're still new, and the new AFM/turbo engines are a far cry from what they used to be -- they used to have engines like the pushrod 5.7/6.0 Vortec (which was LS baed) and DuraMax diesels like the 2007 LBZ, and the diesels were pre-emissions before 2007.5 -- but the 2007.5s retained the Allison transmissions when they retired the LBZ DuraMax.
Even their newer trucks in the eras of emissions goals went to i4 engines in Silverados which are known to go bad at 115-120k miles with towing. They're not all bad news, but not the same as the 2007 and older platforms.
이 답변이 도움이 되었나요?
Do you know where valve to bleed air out of system cause I surely can’t find it and temp sensor wire was all messed up up it was pinch with the heater core hose I got it had lot look water damage dash is in price and everything under the front end has rust I replace most of it I replaced cluster other one u couldn’t see nothing on it
@frankshell35512 There's two ways -- if it has a bleed valve, it's on the top side of the engine coolant outlet pipe (front of engine, near the intake manifold). If not, you fill the coolant tank to the cold fill mark and run the AC on max, you need to add coolant as you go but once it's stable it's bled.
My ac don’t work doesn’t even have ac compressor but thanks there email I get hold of u if I have any more problems
On my small scanner it flag it at 170 and show it at first mark on temp gauge like 125 guess might be cluster lately gas gauge show it almost empty it fill up with 15 dollars or time it fill up with 40 bucks
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 228
댓글 2개
@frankshell35512 what temperature is it or does it show you? To hot; to cold? Give us more details.
oldturkey03 의
I think I finally got up to temp sensor start to barely leak and fired pigtail I replaced sensor n pigtail thanks
Frank Shell 의
