주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1706 / EMC 3071—2016년 11월 출시된 이 13형 MacBook Pro는 OLED 터치 바를 도입했습니다. 듀얼 코어 "Skylake" Intel Core i5 CPU와 4개의 썬더볼트 3 포트를 탑재했습니다.
Touch ID flex cable separated from button during battery replacement
I was following the battery replacement guide for this Macbook and the flex cable slid out of the Touch ID / power button contact. The end of the cable doesn't look damaged but I can't tell if it's possible to reconnect it. I tried gently pushing the end of the cable back into the slot and it sort of stays there, but obviously if the cable snapped internally or something that won't work.
I know I can order a full replacement button as a last resort but I'd like to repair this and preserve the Touch ID functionality if at all possible. Any help would be appreciated, even if it's just solemn confirmation that I'm SOL. :)
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Unfortunately, that cable isn't supposed to be separate; it's definitely broken. There are people who can repair broken flex cables, but it requires very specialized expertise, and I have no idea whether the button can be disassembled far enough to access the other half of that broken cable.
LIkewise, there are folks out there who may be able to remove a chip and move it to another button with a good flex cable, but again, that's a niche set of skills that may be hard to find.
In general, the only way to restore Touch ID is to have Apple do the repair, sorry to say. I checked Apple's self service repair portal, and the oldest 13" MacBook Pro that's supported is the M1 model, so that's not an option for you.
Wish I had better news, but Apple has deliberately made it impossible for anyone but them to restore either Touch ID or Face ID. Obviously you'll need a power button, but it looks like you're going to have to figure on living without Touch ID.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you Jerry! Not the answer I wanted to hear but it's the one I expected. I checked out some videos of people doing this kind of niche microscopic repair and they have some space-age workbench setups, so that's a no-go for me; it looks like I'll have to settle for a shiny new functional power button with no Touch ID, but at least it's a way forward. Thank you again!
의
댓글 달기
답변을 추가하세요
Mitchell T 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 34
전체 시간: 263
