주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
본 페이지는 Sony PS2 Slimline (SCPH-750xx)의 문제해결 및 설치 안내서입니다. Sony PlayStation 2 Slimline 게임기는 작고 슬림한 디자인의 네트워크 지원 게임기입니다.
Optical Drive not working.
Heyy,
I had a PS2 Slim (Pink Version) SCPH-77004 with a broken shell (the rest was completely fine)
To replace the shell I ordered a defective and labeled as "Don't Reads Discs)"(Same Type, Same model of course) (might be a different MB Version, didn't checked)
The spare wasn't opened before. Like described it booted and was behaving normal in home screen, it didn't read a disc, but furthermore it didn't seem to even show life of the Laser Assembly (no Motor Spinning, no Laser movement)
That's when I started disassembly, first I checked/tested the two lid switches, both pressed, same result. Both tested good with a multimeter
I tried the working Assembly from my own Slim, and had the same result. The rail tested in my Slim showed Laser Movement and the motor was spinning up. (Didn't read discs, made clicking noises)
I did the same thing with the ribbon cable (so using the ribbon vice versa on both machines) which also provided the same results, I inspected the board of the Spare one and didn't saw any (obvious) issues. And I also checked the Ribbon connectors for lose (cold) connections.
The Spare also didn't looked dirty inside at all, it was like opening a never used console.
So in short:
Laser Assembly good
Ribbon cable good
Ribbon cable connectors good
No obvious MB issue (with Eyes)
Lid switches fine
My question now is, what could it be? Where could/should I start looking for an issue? Did anyone had a similar problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Best thing is to follow this video: https://www.youtube.com/watch?v=Pthhet1_...
It can be way more then the laser and the lid switches (good thing you've checked those, as when they are faulty nothing is moving at all).
I would check your symptoms and see what issue it's having. I think it's something on the motherboard that died...
Can you let us know how it goes?
Thanks!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
TheToptic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 15
전체 시간: 94
