Battery-only part-adhesive?
If I order battery for my iphone, just the part...does it come with adhesive? Or do I have to buy it separately?
좋은 질문입니까?
좋은 질문입니까?
Assuming you're talking about buying a battery from iFixit, the answer is stated under the Description heading in the right-hand column.
- Battery adhesive is preinstalled to improve the quality of your repair.
So yes, it does come with adhesive already installed on the battery; all you have to do is peel off the protective film and you're ready to install.
Protip: Be sure to plug in the battery connector before setting the battery in place, set the battery down and press it down, then unplug it again. Take it from me - and I learned this through experience - if you just set the battery in place, there's enough room for it to be placed such that the connector on the battery is out of reach of the socket on the motherboard. So don't be me, okay?
이 답변이 도움이 되었나요?
I see...to be accurate, I meant display adhesive.
@radekgomola Ah, then no, the precut adhesive for the screen is not included with the part only battery; you'll have to order that separately. Since the adhesive is the same price as the fix kit when ordered by itself, I'd say you might as well get the kit. Otherwise you can find it cheaper on places like eBay or AliExpress if needed, but not by much.
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 165
