주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Charging light but power button does nothing
Hi
I have a 2ds XL that won't turn on, it charges fine and I have tried a known working battery with no luck, the blue light never comes on, I have checked the 2 fuses and they have continuity, I did check for vaultage on the power button but it doesn't seem to be getting any power when pressed, but it gets continuity, wondering where and how I should test from here
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
You have tested a lot already. Since the battery and fuses are OK, it would be difficult to find where the fault is.
Must be somewhere in the power area near the battery. The power button should work when it gives continuity.
How are the battery pins? Still good? No corrosion?
It could be a lot of things. I think it's easier (I know, it's more expensive..) to get a new motherboard.
Guide: New Nintendo 2DS XL 마더보드 교체
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Well it's more of a want to learn more than a need to fix it lol, guess I just need to learn to follow traces and check where the vaultage stops at this point
I would check near the battery, that location!
You can find some more info here: https://gbatemp.net/threads/n2ds-xl-wont...
댓글 달기
답변을 추가하세요
Yelo Hill 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 24
전체 시간: 197
