주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
배터리 라디오 타임 서버 기반 시계
Time changes automatically with buzzing sou6
Why in my digital alarm clock time changes automatically with buzzing sound
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This clock uses a Radio Time Server to set its time, that's not to say what's offered is correct as the time zone setting and which time service your click is using may not be correctly set. Make sure the offset from GMT is correct for your location and once set the clock is able to hear the radio signal otherwise it will using its own built in time base.
Things to check is the clock near an outside wall, southward is the best direction in the northern hemisphere. Are the walls brick or metal which can block the signal. If you have a hard time with your cellphone that's a good clue.
The buzzing maybe a messed up Alarm speaker. Here's the product page TFA 602511 Alarm Clock
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
SUJAYA KUMAR ROUT 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 29
전체 시간: 154
